Saltar al contenido principal
Lenovo ThinkPad x120e Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad x120e Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Lenovo ThinkPad x120e Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: paso 2, imagen 1 de 3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: paso 2, imagen 2 de 3 Lenovo ThinkPad x120e Hard Drive Replacement, Back Cover: paso 2, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Lenovo ThinkPad x120e Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Under the back cover, you'll find the drive bay containing the hard drive on the top left.
    • Using the Phillips #0 screwdriver, remove two 4 mm screws which are located on the top left and bottom right corners.
    • Slide out the hard drive from the back cover horrizontally.
    • The pictures only show the mount, not the actual hard drive. Unfortunately, the hard drive was lost during replacement.
  4. Lenovo ThinkPad x120e Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad x120e Hard Drive Replacement: paso 4, imagen 2 de 2
    • Using the same Phillips #0 screwdriver, remove the four 4 mm screws located on each side of the drive bay.
    • Remove the physical hard drive from the drive bay.
Conclusión
Jacob Fronzaglia
Miembro Desde 10/25/21
787 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 3-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 236
