Saltar al contenido principal
Lenovo ThinkPad Yoga Screen Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga Screen Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad Yoga Screen Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad Yoga Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Screen Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Yoga Screen Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Yoga Screen Replacement: paso 2, imagen 3 de 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Screen Replacement, Screen: paso 3, imagen 1 de 3 Lenovo ThinkPad Yoga Screen Replacement, Screen: paso 3, imagen 2 de 3 Lenovo ThinkPad Yoga Screen Replacement, Screen: paso 3, imagen 3 de 3
    • Remove two screws under the plastic covers on the front of the screen using a Phillips #0 screwdriver.
    • Pry the plastic cover off with a spudger.
    • Remove the two screws from underneath the cover using a Phillips #0 screwdriver.
    • Detach the screen connector from the rest of the laptop.
  4. Lenovo ThinkPad Yoga Screen Replacement: paso 4, imagen 1 de 1
    • Remove the screen from the rest of the laptop.
Conclusión
Michael Nessralla
Miembro Desde 10/28/21
171 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 28
Ultimos 30 días: 108
Todo El Tiempo: 2,333
