Saltar al contenido principal
Lenovo ThinkPad Yoga Keyboard Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement: paso 2, imagen 3 de 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: paso 3, imagen 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: paso 3, imagen 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: paso 3, imagen 3 de 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: paso 4, imagen 1 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: paso 4, imagen 2 de 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: paso 4, imagen 3 de 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: paso 5, imagen 1 de 1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: paso 6, imagen 1 de 1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Felicia McCarey
Miembro Desde 10/28/21
299 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 54
Ultimos 30 días: 254
Todo El Tiempo: 7,458
