Saltar al contenido principal
Lenovo ThinkPad Yoga 370 Screen Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: paso 4, imagen 1 de 1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Screen Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Screen Replacement: paso 5, imagen 3 de 3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Conclusión
Una persona más ha completado esta guía.
Un comentario
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 88
Todo El Tiempo: 2,299
