Saltar al contenido principal
Lenovo ThinkPad Yoga 370 Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 370 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set aside.
  2. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #00 screwdriver, unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 5, imagen 3 de 3
    • Gently pull back the heat shield on the hard drive without tearing it or completely removing it.
  6. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the 5mm screw and set aside.
  7. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Using two fingers, gently pull the hard drive straight out of the connection to remove it from device.
Conclusión
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 49
Todo El Tiempo: 3,409
