Saltar al contenido principal
Lenovo ThinkPad Yoga 370 Fan Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 370 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 3, imagen 2 de 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 4, imagen 2 de 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 5, imagen 3 de 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 6, imagen 3 de 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fan Replacement, Fan: paso 7, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Remove the four 2 mm screws holding the heatsink to the motherboard using the Phillips #00 screwdriver.
  8. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Disconnect the fan's bundled cable from the motherboard using a small set of tweezers or simply pull them out gently.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  9. Lenovo ThinkPad Yoga 370 Fan Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad Yoga 370 Fan Replacement: paso 9, imagen 2 de 2
    • The fan is not ready to be removed yet. When lifting the fan from the frame, keep it within 2 inches from the motherboard until the attached wire is removed.
    • Lift the fan and heatsink from the motherboard; then flip both toward the motherboard.
    • Detach the wire from the perimeter of the fan casing.
    • Remove the fan and heatsink.
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 976
