Saltar al contenido principal
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 3, imagen 2 de 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 4, imagen 2 de 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: paso 5, imagen 1 de 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: paso 5, imagen 2 de 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: paso 5, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 6, imagen 2 de 2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: paso 7, imagen 2 de 2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 20
Todo El Tiempo: 890
