Saltar al contenido principal
Lenovo ThinkPad Yoga 260 Back Cover Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 260 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 3, imagen 2 de 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: paso 4, imagen 2 de 2
    • Place your fingers around the edges of the cover and remove it.
Conclusión
To reassemble your device, follow these instructions in reverse order
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S2-G3, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 2,314
