Saltar al contenido principal
Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement
Qué necesitas
  1. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Battery: paso 1, imagen 1 de 1
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: paso 2, imagen 2 de 2
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Wi-Fi Board: paso 3, imagen 1 de 2 Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement, Wi-Fi Board: paso 3, imagen 2 de 2
    • Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad Yoga 11e Gen 6 Wi-Fi Board Replacement: paso 4, imagen 3 de 3
    • Lift the two wires and plastic piece away from the Wi-Fi board.
    • Remove the single 3 mm screw holding the Wi-Fi board in place using a Phillips #0 screwdriver.
    • Hold the sides of the Wi-Fi board and slide it out of the socket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 58
