Introducción
The Lenovo ThinkPad Yoga 11e Gen 6 may need a new battery if the battery life is shorter than expected when it is disconnected from a power source. A short battery life could mean that the battery is swollen, which is a potential fire hazard and needs to be replaced immediately. This guide will explain and show the process of replacing the battery step-by-step.
Qué necesitas
Disconnect the laptop from power and make sure it is completely powered off.
Turn the laptop facing down.
Loosen the eight captive screws using a JIS #0 screwdriver.
Use a spudger to release the tabs securing the back case and carefully remove the panel.
2 personas más completaron esta guía.
