Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. First flip your device over so its bottom is facing up. Next, locate where the two Philip #00  screws are marked in the image, and unscrew them as shown. Next, locate where the two Philip #00  screws are marked in the image, and unscrew them as shown.
    • First flip your device over so its bottom is facing up.
    • Next, locate where the two Philip #00 screws are marked in the image, and unscrew them as shown.
  2. Now with the loosened screws, you can easily pull back the metal compartment cover to get to where RAM is stored.
    • Now with the loosened screws, you can easily pull back the metal compartment cover to get to where RAM is stored.
  3. After opening up the compartment, you simply pull out the two RAM units and replace them with the new RAM.
    • After opening up the compartment, you simply pull out the two RAM units and replace them with the new RAM.
Conclusión
Ryan McCarthy
Miembro Desde 15/03/18
748 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 175
