Saltar al contenido principal
  1. The first  step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. The next step is to simply move the switch from the locked position to the unlocked position.
    • The next step is to simply move the switch from the locked position to the unlocked position.
  4. Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
Conclusión
2 personas más completaron esta guía.
Ryan McCarthy
Miembro Desde 15/03/18
748 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 18
Todo El Tiempo: 211
