Saltar al contenido principal
Lenovo ThinkPad X390 Yoga Speakers Replacement
Qué necesitas
  1. Lenovo ThinkPad X390 Yoga Speakers Replacement, Back Case: paso 1, imagen 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Speakers Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Speakers Replacement: paso 3, imagen 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Speakers Replacement, Battery: paso 4, imagen 1 de 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Speakers Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Speakers Replacement: paso 6, imagen 1 de 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Speakers Replacement, Speaker: paso 7, imagen 1 de 1
    • Disconnect the connector wire by gently pulling away from the port.
  8. Lenovo ThinkPad X390 Yoga Speakers Replacement: paso 8, imagen 1 de 1
    • Remove the speaker by lifting them up.
    • Gently lift the speaker cable that connects the two speakers from the perimeter of the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 336
