Saltar al contenido principal
Lenovo ThinkPad X390 Touchpad Replacement
Qué necesitas
  1. Lenovo ThinkPad X390 Touchpad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Touchpad Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X390 Touchpad Replacement: paso 2, imagen 2 de 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Touchpad Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X390 Touchpad Replacement, Battery: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Touchpad Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad X390 Touchpad Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Touchpad Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X390 Touchpad Replacement: paso 5, imagen 2 de 2
    • Using your hands, remove the battery from the laptop.
  6. Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: paso 6, imagen 1 de 2 Lenovo ThinkPad X390 Touchpad Replacement, Touchpad: paso 6, imagen 2 de 2
    • After removing the battery, disconnect the trackpad from the laptop's motherboard
    • Using a plastic spudger, flip up the black plastic cover to release the cable.
    • Use a finger to hold back the cable to make accessing the connection easier.
  7. Lenovo ThinkPad X390 Touchpad Replacement: paso 7, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the four 2.0 mm screws securing the touchpad to the device.
  8. Lenovo ThinkPad X390 Touchpad Replacement: paso 8, imagen 1 de 1
    • Lift up the bottom portion of the laptop and remove the trackpad.
Conclusión
Curtis Kubacka
Miembro Desde 09/28/21
261 Reputación
2 Guías creadas
Equipo
Clemson, Team 5-1, Hunter Fall 2021 Miembro de Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 61
Todo El Tiempo: 1,294
