Saltar al contenido principal
Lenovo ThinkPad X390 Fan Replacement
Qué necesitas
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X390 Fan Replacement: paso 2, imagen 2 de 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: paso 3, imagen 1 de 1
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: paso 5, imagen 1 de 1
    • Lift the fan up and out and remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Nick Couch
Miembro Desde 09/28/21
252 Reputación
1 Guía escrita
Equipo
Clemson, Team 5-1, Hunter Fall 2021 Miembro de Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 48
Todo El Tiempo: 940
