Saltar al contenido principal
Lenovo ThinkPad X280 Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Back Panel: paso 1, imagen 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to gently disconnect the two wires that are connected to the Wi-Fi card.
    • They should pop off with minimal force.
  5. Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
    • Be careful not to over-tighten the screw when reassembling, should be thumb tight
  6. Lenovo ThinkPad X280 Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
    • Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 55
Todo El Tiempo: 943
