Saltar al contenido principal
Lenovo ThinkPad X280 Fan Assembly Replacement
Qué necesitas
  1. Lenovo ThinkPad X280 Fan Assembly Replacement, Back Panel: paso 1, imagen 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Fan Assembly Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X280 Fan Assembly Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Fan Assembly Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X280 Fan Assembly Replacement: paso 3, imagen 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: paso 4, imagen 1 de 2 Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: paso 4, imagen 2 de 2
    • Using the Phillips #1 screwdriver, loosen the four captive screws attached to the heat sink until a small pop sound heard.
    • The screws do not come all the way out and remain partially attached to the heat sink.
  5. Lenovo ThinkPad X280 Fan Assembly Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X280 Fan Assembly Replacement: paso 5, imagen 2 de 2
    • Using the black spudger, gently push out the gray plastic connecter from the plug.
  6. Lenovo ThinkPad X280 Fan Assembly Replacement: paso 6, imagen 1 de 1
    • Loosen and remove the fan.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 24
Ultimos 30 días: 85
Todo El Tiempo: 2,215
