Saltar al contenido principal
Lenovo ThinkPad X280 CMOS Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X280 CMOS Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 CMOS Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X280 CMOS Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 CMOS Battery Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X280 CMOS Battery Replacement: paso 3, imagen 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: paso 4, imagen 1 de 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: paso 4, imagen 2 de 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 CMOS Battery Replacement, CMOS Battery: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to gently unplug the CMOS Battery from the port on the right side.
  6. Lenovo ThinkPad X280 CMOS Battery Replacement: paso 6, imagen 1 de 1
    • Work the wire out from its holding brackets and is now free to be removed.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 44
Ultimos 30 días: 156
Todo El Tiempo: 2,240
