Saltar al contenido principal
Lenovo ThinkPad X260 Internal Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: paso 1, imagen 1 de 2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: paso 1, imagen 2 de 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 2, imagen 3 de 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: paso 3, imagen 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: paso 3, imagen 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: paso 3, imagen 3 de 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 4, imagen 3 de 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: paso 5, imagen 1 de 2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: paso 6, imagen 1 de 1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: paso 7, imagen 1 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 7, imagen 2 de 3 Lenovo ThinkPad X260 Internal Battery Replacement: paso 7, imagen 3 de 3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
Conclusión
Ammarin Sinthana
Miembro Desde 07/13/23
97 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-3, Harley Summer 2023 Miembro de IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 36
Ultimos 30 días: 138
Todo El Tiempo: 1,439
