Saltar al contenido principal
Lenovo ThinkPad X260 Back Cover Replacement
Qué necesitas
  1. Lenovo ThinkPad X260 Back Cover Replacement, External Battery: paso 1, imagen 1 de 2 Lenovo ThinkPad X260 Back Cover Replacement, External Battery: paso 1, imagen 2 de 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Back Cover Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad X260 Back Cover Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad X260 Back Cover Replacement: paso 2, imagen 3 de 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: paso 3, imagen 1 de 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: paso 3, imagen 2 de 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: paso 3, imagen 3 de 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Back Cover Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad X260 Back Cover Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad X260 Back Cover Replacement: paso 4, imagen 3 de 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
Conclusión
Alexander Webb
Miembro Desde 12/06/21
193 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-3, Harley Summer 2023 Miembro de IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 368
