Saltar al contenido principal
Lenovo ThinkPad X140e Speakers Replacement
Qué necesitas
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: paso 1, imagen 1 de 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X140e Speakers Replacement: paso 2, imagen 2 de 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 3, imagen 3 de 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 4, imagen 3 de 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: paso 5, imagen 1 de 1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X140e Speakers Replacement: paso 6, imagen 2 de 2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad X140e Speakers Replacement: paso 7, imagen 2 de 2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: paso 8, imagen 1 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 8, imagen 2 de 3 Lenovo ThinkPad X140e Speakers Replacement: paso 8, imagen 3 de 3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
Conclusión
Dylan Halland
Miembro Desde 10/05/16
318 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-5, Livingston Fall 2016 Miembro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 2,820
