Saltar al contenido principal
Lenovo ThinkPad X140e Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad X140e Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: paso 2, imagen 2 de 2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
  4. Lenovo ThinkPad X140e Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • After removing the back panel, locate the hard drive located to the far left. It is distinguishable from other parts based on it's rectangular shape.
  5. Lenovo ThinkPad X140e Hard Drive Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove the four 3.5 mm Phillips #0 screws attached on the four corners of the hard drive.
  6. Lenovo ThinkPad X140e Hard Drive Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X140e Hard Drive Replacement: paso 6, imagen 2 de 2
    • Slide the hard drive to the left.
    • Grip the hard drive on both sides and proceed to lift up to remove the hard drive.
Conclusión
Una persona más ha completado esta guía.
kevin hull
Miembro Desde 10/05/16
213 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-5, Livingston Fall 2016 Miembro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Miembros
5 Guías creadas
Un comentario
How do you reformat the hard-drive? I understand physically replacing the equipment, but how do I reformat it with a windows operating system? My email is amwindham@aol.com.
amwindham - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,643
