Saltar al contenido principal
Lenovo ThinkPad X140e Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: paso 2, imagen 1 de 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X140e Battery Replacement: paso 3, imagen 2 de 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Conclusión
Dylan Halland
Miembro Desde 10/05/16
318 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-5, Livingston Fall 2016 Miembro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Miembros
5 Guías creadas
Un comentario
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 961
