Saltar al contenido principal
Lenovo ThinkPad X1 Yoga Trackpad Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: paso 1, imagen 3 de 3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Speakers: paso 2, imagen 1 de 1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 4, imagen 3 de 3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: paso 5, imagen 3 de 3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 6, imagen 1 de 1
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Trackpad: paso 7, imagen 1 de 2 Lenovo ThinkPad X1 Yoga Trackpad Replacement, Trackpad: paso 7, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove four 4.5 mm screws from the trackpad.
  8. Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 8, imagen 2 de 2
    • Using the iFixit opening tool, flip up the small covers to the track pad cable connectors.
    • Gently pull the cable out of place.
  9. Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad X1 Yoga Trackpad Replacement: paso 9, imagen 2 de 2
    • Using iFixit opening tools, lift up the frame of the track pad.
    • Gently remove the track pad away from the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 14
Ultimos 30 días: 54
Todo El Tiempo: 2,702
