Saltar al contenido principal
Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Pen Charging Port: paso 4, imagen 1 de 1
    • Remove the pen from its slot on the side of the laptop before removing the pen charging port.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 5, imagen 2 de 2
    • Lift the tab with a spudger to expose the ribbon cable.
    • Do not use the metal spudger unless if it's for serious prying power. The metal spudger may damage or puncture the internal components in your device, so please use a plastic opening tool or nylon spudger instead.
    • Carefully pull out the ribbon cable using Pro/ESD/Angled tweezers.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 6, imagen 2 de 2
    • Disconnect the red and black charger wire from the port on the circuit board.
    • Remove two 4 mm screws using the Phillips #0 screwdriver.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 7, imagen 1 de 1
    • Remove the circuit board by hand.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: paso 8, imagen 2 de 2
    • Remove a single 6 mm screw from the charging port using the Phillips #0 screwdriver.
    • Remove the black charging port using your fingers.
Conclusión
Katrina Lee
Miembro Desde 02/10/20
154 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S22-G3, Regan Winter 2020 Miembro de Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 2,127
