Saltar al contenido principal
Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: paso 4, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Speakers: paso 4, imagen 2 de 2
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/Angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 5, imagen 2 de 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 6, imagen 2 de 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement, Battery: paso 7, imagen 1 de 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 8, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Battery Replacement: paso 9, imagen 1 de 1
    • Remove the battery.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S22-G3, Regan Winter 2020 Miembro de Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Miembros
7 Guías creadas
4 comentarios
thank for your good job ;-)
michaël cadot - Contestar
Thank you for an excellent
John Kihl - Contestar
Where is a good place to buy a replacement battery?
Johann Lopez - Contestar
Any idea where to find the battery? Not listed for sale on ifixit
Brian Arnold - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 69
Ultimos 30 días: 239
Todo El Tiempo: 7,623
