Introducción
The 6th generation Lenovo ThinkPad X1 Yoga is a versatile 2-in-1 laptop launched in 2021. It is a top-notch choice for daily use, whether for work or academics and offers exceptional value for money. Nevertheless, specific laptop components can deteriorate over time, leading to issues. Suppose your laptop is slowing down, having trouble rebooting, or encountering corrupted files. In that case, it might point to a failing SSD. In such a scenario, you can use this guide to replace the SSD in your 6th Gen ThinkPad X1 Yoga in three simple steps.
Qué necesitas
Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
Lift the base panel up and off of the chassis.
Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
Lift the copper plate up and out.
