Saltar al contenido principal
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: paso 1, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: paso 2, imagen 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: paso 2, imagen 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: paso 3, imagen 1 de 1
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 55
Todo El Tiempo: 1,639
