Introducción
Following the steps laid out in this guide will allow you to replace the internal fan of the Lenovo ThinkPad X1 Yoga (6th Gen) laptop. This repair may be needed if you cannot hear the fan running during operation, and/or your laptop is consistently overheating. Before outright replacement, make sure the fan's blades are free of dirt or debris buildup that may reduce the fan's efficiency.
Qué necesitas
Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
Lift the base panel up and off of the chassis.
Un comentario
Hi, Do you know what is the fan part number? Where did you get the fan from?
