Saltar al contenido principal
Lenovo ThinkPad X1 Extreme Trackpad Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Speakers: paso 2, imagen 1 de 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Trackpad Replacement: paso 3, imagen 1 de 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: paso 4, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: paso 4, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Trackpad Replacement: paso 5, imagen 1 de 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Trackpad: paso 6, imagen 1 de 1
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the four screws that are holding the trackpad to the Thinkpad using a 1.5 mm flathead screwdriver.
  7. Lenovo ThinkPad X1 Extreme Trackpad Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad X1 Extreme Trackpad Replacement: paso 7, imagen 2 de 2
    • Use a spudger to release the retaining tab on the trackpad cable connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 1,534
