Saltar al contenido principal
Lenovo ThinkPad X1 Extreme SSD Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: paso 2, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Extreme SSD Replacement: paso 3, imagen 2 de 2
    • Using the opening tool, pop out the SSD card and remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 44
Todo El Tiempo: 2,305
