Introducción
If your Lenovo ThinkPad X1 Gen 1 Extreme (model number 20MF-000LUS used in this guide) is overheating or making clicking noises, use this guide to remove the fan.
While this laptop has been noted to get quite hot and loud, this should typically only occur when charging or using high intensity applications. The laptop should not be overheating when idle.
Keep in mind that an entire replacement of the fan may not be necessary, as the problem could potentially be built up dust or a foreign object. If this is the case, removing the fan and cleaning it out with compressed air could solve the issue.
Qué necesitas
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Herramienta utilizada en este paso:Tweezers$4.99
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Herramienta utilizada en este paso:Phillips #00 Screwdriver$5.49
Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
Slide the adapter out of its connector.
Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
Una persona más ha completado esta guía.
Un comentario
You only need to complete steps 1, 8, & 9. The cables for the wireless card come out of the side of the fan assembly without unplugging them. If you want to disconnect the battery for peace of mind you can do that without removing the battery. Definitely don't need to remove the speakers. I came across this guide looking for a replacement fan part but have done this particular job twice and removed the fan on another occasion to bench test it, so I've done the process 3 times. Seems like the author was hunting for additional steps for more brownie points but it's much simpler than that.
