Saltar al contenido principal
Lenovo ThinkPad X1 Extreme Charging Port Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: paso 2, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: paso 2, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Phillips #00 Screwdriver
    $5.49
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  3. Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 3, imagen 2 de 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  4. Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 4, imagen 2 de 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  5. Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 5, imagen 3 de 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Charging Port: paso 6, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the two screws on the cover of the charging port.
  7. Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: paso 7, imagen 2 de 2
    • Disconnect the charging port cable from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 2,340
