Saltar al contenido principal
Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Back cover removal: paso 1, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Back cover removal: paso 1, imagen 2 de 2
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: paso 2, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: paso 2, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Insert an opening pick: paso 2, imagen 3 de 3
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: paso 3, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: paso 3, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the back cover: paso 3, imagen 3 de 3
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Unfasten the battery: paso 4, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Unfasten the battery: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Remove the battery: paso 5, imagen 3 de 3
    • Lift the battery straight out of its recess and remove it.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Track Pad: paso 6, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement, Track Pad: paso 6, imagen 2 de 2
    • Peel back the black adhesive tape covering the ribbon cable connecting the trackpad and fingerprint scanner to the motherboard.
    • Remove the four 2mm screws securing the trackpad with a Phillips #000 screwdriver.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: paso 7, imagen 1 de 1
    • Use an opening tool to lift up the connecter ribbon lock and pull the connector ribbon out allowing the track pad to be removed.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 7th Gen Track Pad Replacement: paso 8, imagen 2 de 2
    • Flip the laptop over and open it.
    • Use an opening pick to carefully lift the trackpad out.
Conclusión
3 personas más completaron esta guía.
Oliver Parker
Miembro Desde 01/23/20
151 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S19-G2, White Winter 2020 Miembro de Cal Poly, Team S19-G2, White Winter 2020
CPSU-WHITE-W20S19G2
4 Miembros
20 Guías creadas
Un comentario
Where did you get the new trackpad?
janamansour - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 32
Ultimos 30 días: 123
Todo El Tiempo: 3,798
