Saltar al contenido principal
Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Battery: paso 3, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 4, imagen 1 de 1
    • Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 3 de 3
    • Locate the Wi-Fi Card on the side of the device opposite to the fan. It should have one black and one white pin connector wires as well as one retainer screw.
    • Use a plastic opening tool to lift up the two coaxial cables from the Wi-Fi Card.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #0 Screwdriver to unscrew the 3 mm screw holding down the Wifi card.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Carefully slide the Wifi Card towards the center of the device to disconnect it.
    • It may help to use an opening tool to get some leverage and slide it out.
  8. Lenovo ThinkPad X1 Carbon 6th Gen Wi-Fi Card Replacement: paso 8, imagen 1 de 1
    • Your Wifi Card is now removed.
Conclusión
5 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 118
Todo El Tiempo: 6,866
