Saltar al contenido principal
Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: paso 4, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 5, imagen 3 de 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, CMOS Battery: paso 6, imagen 1 de 1
    • Once the battery is removed the CMOS battery will be exposed.
  7. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 7, imagen 2 de 2
    • Disconnect the CMOS cable from the socket on the motherboard.
  8. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: paso 8, imagen 1 de 1
    • Remove the CMOS battery.
Conclusión
Una persona más ha completado esta guía.
Equipo
Gateway, Team 1-3, Saknee Fall 2021 Miembro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 29
Ultimos 7 días: 166
Ultimos 30 días: 810
Todo El Tiempo: 19,018
