Saltar al contenido principal
Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement: paso 2, imagen 2 de 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Battery: paso 3, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement: paso 4, imagen 1 de 1
    • Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Speakers: paso 5, imagen 1 de 3 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Speakers: paso 5, imagen 2 de 3 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement, Speakers: paso 5, imagen 3 de 3
    • Gently grab the widest edges of the speaker cable and pull the cable out towards the speakers.
    • Use a Phillips #0 screwdriver to remove the four 5 mm screws.
  6. Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (6th Gen) Speakers Replacement: paso 6, imagen 2 de 2
    • The cable between the two speakers is interwoven between a plastic retainer. It can be easier to remove in a zig-zag motion.
    • Lift the speakers starting with the cable you disconnected earlier. Continue to unravel the cable between the two speakers until the unit lifts freely.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 66
Todo El Tiempo: 1,702
