Saltar al contenido principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: paso 3, imagen 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 5, imagen 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: paso 6, imagen 1 de 1
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: paso 8, imagen 1 de 1
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
Conclusión
Una persona más ha completado esta guía.
Eevee Murdock
Miembro Desde 01/23/20
1,110 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S18-G4, White Winter 2020 Miembro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
Miembros de 4
9 Guías creadas
2 comentarios
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - Contestar
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 39
Todo El Tiempo: 1,909
