Saltar al contenido principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: paso 3, imagen 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 5, imagen 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: paso 6, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: paso 6, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 7, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 7, imagen 2 de 2
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 8, imagen 2 de 2
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: paso 9, imagen 1 de 1
    • Remove the speakers by lifting them directly upward.
Conclusión
Eevee Murdock
Miembro Desde 01/23/20
1,086 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S18-G4, White Winter 2020 Miembro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,040
