Saltar al contenido principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: paso 3, imagen 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 5, imagen 1 de 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Fan: paso 6, imagen 1 de 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 7, imagen 1 de 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: paso 8, imagen 1 de 1
    • Remove the fan by lifting it directly up.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S18-G4, White Winter 2020 Miembro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 27
Todo El Tiempo: 1,141
