Saltar al contenido principal
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: paso 3, imagen 1 de 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery by pulling it directly towards you.
Conclusión
9 personas más completaron esta guía.
Eevee Murdock
Miembro Desde 01/23/20
1,110 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S18-G4, White Winter 2020 Miembro de Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
Miembros de 4
9 Guías creadas
4 comentarios
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - Contestar
Any comments from @ifixit?
Martin Optilon - Contestar
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 88
Todo El Tiempo: 5,753
