Saltar al contenido principal
Lenovo ThinkPad W550S BIOS Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad W550S BIOS Battery Replacement, Open the case: paso 1, imagen 1 de 1
    • Make sure the laptop is off and remove the battery.
    • Loosen all screws (these remain in the case bottom) with a PH 00 screwdriver.
    • Open the clips around the case with an iFixit opening tool.
  2. Lenovo ThinkPad W550S BIOS Battery Replacement, Opening the case: paso 2, imagen 1 de 1
    • To remove the case bottom, you have to lift it slightly and push it backwards.
    • Be careful not to damage the case!
  3. Lenovo ThinkPad W550S BIOS Battery Replacement, Remove battery: paso 3, imagen 1 de 1
    • Carefully remove the foil
    • Disconnect the plug of the battery.
    • Remove the battery from the circuit board. This is glued to the circuit board with a spacer.
  4. Lenovo ThinkPad W550S BIOS Battery Replacement, Replace battery: paso 4, imagen 1 de 1
    • Find a replacement battery based on the type designation (in my case a 08K8050 - CR 2032 3V) and insert it.
Conclusión
Work through the steps in reverse order to reassemble your device.
Un agradecimiento especial a estos traductores:
de en
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Michael
Miembro Desde 02/28/17
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 22
Todo El Tiempo: 1,125
