Introducción
Hello everyone, in this guide Ill be showing you how to open the laptop in order to change the thermal paste, as well as to possibly upgrade the RAM or the SSD inside.
Qué necesitas
Unscrew the 8 screws holding the back panel in place.
Remove the first battery by sliding the notches and pulling the battery outwards.
Use a prying tool to carefully release all the clips holding the panel in place.
It is recommended to disconnect the second battery too.
Unscrew the screws holding the CPU heatsink and disconnect the fan.
Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
You can also open the fan assembly to clean it better.
Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Dont forget to plug in the second battery before closing the back panel!
Una persona más ha completado esta guía.
