Saltar al contenido principal
Lenovo ThinkPad T580 Case Replacement
Qué necesitas
  1. Lenovo ThinkPad T580 Case Replacement, External Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T580 Case Replacement, External Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T580 Case Replacement, External Battery: paso 1, imagen 3 de 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Case Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T580 Case Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T580 Case Replacement: paso 2, imagen 3 de 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Case Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T580 Case Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T580 Case Replacement: paso 3, imagen 3 de 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Case Replacement, Bottom Case: paso 4, imagen 1 de 2 Lenovo ThinkPad T580 Case Replacement, Bottom Case: paso 4, imagen 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Case Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T580 Case Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T580 Case Replacement: paso 5, imagen 3 de 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Case Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad T580 Case Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad T580 Case Replacement: paso 6, imagen 3 de 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
Conclusión
Ben Elkayam
Miembro Desde 01/23/20
954 Reputación
8 Guías creadas
Equipo
Cal Poly, Team S18-G6, White Winter 2020 Miembro de Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 13
Ultimos 30 días: 45
Todo El Tiempo: 1,606
