Saltar al contenido principal
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: paso 4, imagen 1 de 1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove SSD/Hard Drive case from the drive.
Conclusión
2 personas más completaron esta guía.
Equipo
Clemson, Team 1-3, Hunter Spring 2022 Miembro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 51
Ultimos 30 días: 187
Todo El Tiempo: 5,863
