Saltar al contenido principal
Lenovo ThinkPad T560 Back Panel Replacement
Qué necesitas
  1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Back Panel Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
Conclusión
Equipo
Clemson, Team 1-3, Hunter Spring 2022 Miembro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
Miembros de 5
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 57
Todo El Tiempo: 1,091
