Saltar al contenido principal
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: paso 1, imagen 1 de 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 1 de 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 2 de 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 778
