Saltar al contenido principal
Lenovo ThinkPad T495 RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T495 RAM Replacement, Baseplate: paso 1, imagen 1 de 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 RAM Replacement: paso 2, imagen 1 de 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 RAM Replacement, RAM: paso 3, imagen 1 de 2 Lenovo ThinkPad T495 RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Lift the black flap to expose the RAM.
  4. Lenovo ThinkPad T495 RAM Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T495 RAM Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T495 RAM Replacement: paso 4, imagen 3 de 3
    • Use your fingers to gently pull the two arms on each side horizontally until the RAM springs up.
    • Grip the RAM between your fingers and pull it gently until it releases from the port.
    • When reinstalling the RAM, push it down vertically, toward the motherboard, until the arms audibly click, securing the RAM in place.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 49
Ultimos 30 días: 233
Todo El Tiempo: 3,883
