Saltar al contenido principal
Lenovo ThinkPad T490 CMOS Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 CMOS Battery Replacement, CMOS Battery: paso 1, imagen 1 de 1
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Insert the iFixit opening tool into the space between the baseplate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 CMOS Battery Replacement: paso 3, imagen 1 de 1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 CMOS Battery Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad T490 CMOS Battery Replacement: paso 4, imagen 2 de 2
    • Locate the battery socket connector parallel to the motherboard.
    • Slide the battery socket connector out of its socket on the motherboard.
  5. Lenovo ThinkPad T490 CMOS Battery Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad T490 CMOS Battery Replacement: paso 5, imagen 2 de 2
    • Unplug the connector from the socket on the motherboard.
    • Pry the coin cell battery off of the motherboard.
  6. Lenovo ThinkPad T490 CMOS Battery Replacement: paso 6, imagen 1 de 1
    • Insert new coin cell battery.
Conclusión
Un comentario
I read in a Lenovo "how to" video that you should go into the BIOS and disable the CMOS battery before replacing.
Jaimo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 170
Todo El Tiempo: 991
