Saltar al contenido principal
Lenovo ThinkPad T490 Base Plate Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 Base Plate Replacement, Base Plate: paso 1, imagen 1 de 1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Base Plate Replacement: paso 2, imagen 1 de 1
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 Base Plate Replacement: paso 3, imagen 1 de 1
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 93
Todo El Tiempo: 715
